Multisim and Ultiboard
Importing a SPICE model (74ALVC16244A) into Multisim
Can somebody tell me how to easily import this spice model into Multisim?
The Component Wizard seems complicated. Or can someone help make is model?
Thanks very much!!
Message 1 of 18
(10,662 Views)
Hi
I tried to make a new component by following Multisim component creation tutorial, but I got this message "An error has been found in the Netlist".
And there a bunch of error messages in the simulation tab. This time I am using NC7SZ34 by Fairchild. The mode file ends with .ibs extension.
Can someone help me out?
Message 2 of 18
(10,661 Views)
We do not curretly support IBIS files. Which is what you got there.
Miguel V
Message 3 of 18
(10,638 Views)
Hi Miguel V,
Thanks for replying me. The model for 74ALVC16244A I uploaded first actually is a file with .spi extension. I am gusssing this is a spice model.
Can you help me with this model? I got stuck when making a new model and kept getting errors. I also have another model with .sp extension. Does this one work in Multisim?
Thanks you very much!
Message 4 of 18
(10,628 Views)
Well the first model you got there is a CIR file containing an HSpice model which we also do not support sorry. We only support SPICE models and XSPICE models. Not LTSpice, HSpice, IBIS, etc.
Miguel V
Message 5 of 18
(10,618 Views)
Hi Miguel V,
Thansk for that information.
I have anther question. Do you support .mod extension model? I need another P mosfet model. I have the .mod file and data sheet. And if this kind of file works for Multisim, how can we deal with the pins. I mean, on the data sheet, there are 8 pins on a chip. When we create the componment, we are creating just one mosfet with three pins, right? I know there is a thing called multi-section componment, but I have no idea how to match the 3 pins in a 8-pin chip using this multi-section componment
Looking forward to your reply.
Thanks.
Following is the what contained in the .mod file:
*FDS8433A at Temp. Electrical Model
.SUBCKT FDS8433A 20 10 30 50
*20=DRAIN 10=GATE 30=SOURCE 50=VTEMP
Rg 10 11x 1
Rdu 12x 1 1u
M1 2 1 4x 4x DMOS L=1u W=1u
.MODEL DMOS PMOS(VTO=-0.45 KP=1.6E+1
+THETA=.25 VMAX=9.5E5 LEVEL=3)
Cgs 1 5x 1057p
Rd 20 4 3.25E-3
Dds 4 5x DDS
.MODEL DDS D(M=4.1139E-1 VJ=7.2939E-1 CJO=1082p)
Dbody 20 5x DBODY
.MODEL DBODY D(IS=3.94E-7 N=1.572814 RS=.00064 TT=36.86n)
Ra 4 2 3.25E-3
Rs 5x 5 0.5m
Ls 5 30 0.5n
M2 1 8 6 6 INTER
E2 8 6 4 1 2
.MODEL INTER PMOS(VTO=0 KP=10 LEVEL=1)
Cgdmax 7 4 3000p
Rcgd 7 4 10meg
Dgd 4 6 DGD
Rdgd 4 6 10meg
.MODEL DGD D(M=5E-1 VJ=6.03E-3 CJO=3000p)
M3 7 9 1 1 INTER
E3 9 1 4 1 -2
*ZX SECTION
EOUT 4x 6x poly(2) (1x,0) (3x,0) 0 0 0 0 1
FCOPY 0 3x VSENSE 1
RIN 1x 0 1G
VSENSE 6x 5x 0
RREF 3x 0 10m
*TEMP SECTION
ED 101 0 VALUE {V(50,100)}
VAMB 100 0 25
EKP 1x 0 101 0 .018
*VTO TEMP SECTION
EVTO 102 0 101 0 .001
EVT 11x 12x 102 0 1
*DIODE THEMO BREAKDOWN SECTION
Message 6 of 18
(10,616 Views)
Doesn’t worry about the model file extension, as long as the model is a SPICE or PSPICE, in most cases, it will work in Multisim.   The syntax in the model you copied looks like a SPICE model but it doesn’t look complete.  In the attached model, I’ve added an .ends statement so that the SPICE engine doesn’t complain but it may not work correctly if it’s not a complete model.
This model includes a Vtemp pin so I am assuming you can set the model operating temperature with a voltage source.  In the attached circuit, I’ve connected a 27V DC source to the VTEMP pin so this model is set to operate at 27 degree.  Have a look at the following knowledge base to generate a SPICE model from a circuit if you don’t want to show the VTEMP pin:
http://digital.ni.com/public.nsf/allkb/D1D4AFD6E817CDB986257471006D0F70
It is common to find a SPICE model with fewer pins than the IC.  Any pin that was not modelled should be set to “NC” Multisim Component Wizard model to symbol mapping table.  In this case, the datasheet uses an 8 pin IC but many pins are connected internally so I would stay with a 3 pin MOS symbol.  If you are exporting to layout, when you map the footprint in the Component Wizard, set the drain to pin 5,6,7,8 and the source pin to 1,2 3.
Tien P.
Message 7 of 18
(10,575 Views)
forgot the file,
Tien P.
Message 8 of 18
(10,570 Views)
Hi Tien P,
Thank so much for helping me out! I really appreciate it because I got stuck and felt depressed by this stuff for a couple of days and still have no idea. I kept getting error messages every time when I tried to apply the new component in the circuit.
I don't know if I am asking to much. I still have two models to import. One of them is 74LVT04 another one is a NMOS.
Can you help me make these models?
Here is NMOS:
*FDD6530A at Temp. Electrical Model
.SUBCKT FDD6530A 20 10 30 50
Rg 10 11x 1
Rdu 12x 1 1u
.MODEL DMOS NMOS(VTO=1.15 KP=32.2
+THETA=.166667 VMAX=5.5E5 LEVEL=3)
Cgs 1 5x 620p
Rd 20 4 5E-3
Dds 5x 4 DDS
.MODEL DDS D( M=4.38E-1 VJ=9.64E-1 CJO=258p)
Dbody 5x 20 DBODY
.MODEL DBODY D(IS=2.7E-11 N=2.115781 RS=.0007 TT=8.52n)
Ra 4 2 5E-3
Rs 5x 5 0.5m
Ls 5 30 0.5n
M2 1 8 6 6 INTER
E2 8 6 4 1 2
.MODEL INTER NMOS(VTO=0 KP=10 LEVEL=1)
Cgdmax 7 4 620p
Rcgd 7 4 10meg
Dgd 6 4 DGD
Rdgd 6 4 10meg
.MODEL DGD D(M=3.4E-1 VJ=1.25E-2 CJO=620p)
M3 7 9 1 1 INTER
E3 9 1 4 1 -2
*ZX SECTION
FCOPY 0 3x VSENSE 1
RIN 1x 0 1G
VSENSE 6x 5x 0
RREF 3x 0 10m
*TEMP SECTION
VAMB 100 0 25
EKP 1x 0 101 0 .01
*VTO TEMP SECTION
EVTO 102 0 101 0 .00045
EVT 12x 11x 102 0 1
EBL VB1 VB2 101 0 .08
VBLK VB2 0 20
D 20 DB1 DBLK
.MODEL DBLK D(IS=1E-14 CJO=.1p RS=.1)
EDB DB1 0 VB1 0 1
.ENDS FDD6530A
*FDD6530A (Rev.A) 7/30/03 (TT base @ If=3A)
*ST
Message 9 of 18
(10,564 Views)
Here is the inverter.
Again, thank you very much!!
Best,
ljhconan
Message 10 of 18
(10,563 Views)
