Multisim and Ultiboard
Importing a SPICE model (74ALVC16244A) into Multisim
I think some of these tutorials may help you to create your own parts:
Creating a Custom Component in NI Multisim
How to Import SPICE model in Multisim
How Can I Create a Component in Multisim with Duplicate Pin Names?
Once you created the model and if you have a problem post your circuit with the component placed, I can look at what you did and provide details what went wrong.
Tien P.
Message 11 of 18
(4,279 Views)
Multisim have inverters available and you should use the one from the CMOS database.  Have a look at this knowldege to set the voltage to 3.3V.
http://digital.ni.com/public.nsf/allkb/C2BCB5B0671D888586257AD800598519
The "Ltpkps.txt" file you posted doesn't look like a inverter model, the model only have resistors and inductors.
Tien P.
Message 12 of 18
(4,278 Views)
Thanks very much!
I appreciate your help.
Message 13 of 18
(4,271 Views)
When I do the transient simulation for inverter. My input node is 1, output node is 3. But in the simulation analysis I can just find D(3) instead of V(3) for output. It seems the simulation plot converted the analog into digital automatically. What should I do if I just want to see the real output voltage instead of digital signal?
Thank you very much!
Best,
ljhconan
Message 14 of 18
(4,268 Views)
Hi Tien P.
I made the inverter component from component wizard.
Firstly, it seems there are 6 pins (including 2 hidden pins) on this kind of inverter based on the model file. So I used a typicall inverter model and added two pins. Then there poped out a bunch of error messages.
Secondly I ignore the two power pins by just using typital model (4 pins), still got errors.
This model file should be correct because my friend got it work by using LTspice. So things must go wrong when buliding the model.
Have a fun holiday.
Best,
ljhconan
Message 15 of 18
(4,258 Views)
This model is a complex model and it's calling other models that you did include. For example, this line:
XQQ136 110 111 109 IGND HV38STSBDETCNW
Anything that begins with X is a call command in SPICE and in this case it's looking for another circuit model called HV38STSBDETCNW. Somewhere in this model you should see a line that looks like this:
.subckt HV38STSBDETCNW node1 node2 node3 node4
Since the HV38STSBDETCNW doesn't exist, Multisim will give you an error. This model is calling a lot of different models so you have to include them all. If you can get the LTSPICE circuit from your friend, you should be able to get the complete model.
Tien P.
Message 16 of 18
(4,224 Views)
 how to find spice model for a component ( LM2577-ADJ ) to create this component in multisim
ALI RAJAB
thanks
Message 17 of 18
(2,719 Views)
Hello Alirajab,
To find the spice model for a component, I'd recommend you look in the manufacturers website and see if it's available, if not you'd have to look for it in other places online.
Also for future cases I'd ask you to create a new thread instead of reusing an old one to ask your new questions.
Message 18 of 18
(2,714 Views)
