Multisim and Ultiboard
Importing or creating a sp3t (on-on-on) switch for multisim?
hi,
I'm new to multisim so pls be gentle 😉
I need a switch with more than two on-on positions for a project but can only see a spdt switch in the database. Is there such a thing as a sp3t (on-on-on) switch that I can download/import. I've searched and search but dont seem to be able to find one or make one.
Any help much appreciated.
Thanx in advance,
dean.
(11,660 Views)
no takers?
(11,640 Views)
There is a 4POS_ROTARY switch in the SUPPLEMENTARY_SWITCHES family that you can use to simulate with. You would need 2 of them and just not use POS 4. If you are going to layout a board and need a footprint, you would need to create it.
(11,620 Views)
It doesn't look like there are any components which meet your spec. As mentioned above, I think the closest you can get at the moment is a rotary switch, and just skip one of the positions. Post back if you find or make an sp3t though, it would be a useful one to add to a database for other people to access.
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
(11,603 Views)
deanxxx,
Hope this helps...  Its a SP3T derivative of the interactive 4POS Rotary switch that you've found previously.
Pat Noonan
(11,492 Views)
Help me!!
Edit correct?
_user32 escribió:
deanxxx,
Pat Noonan
(11,170 Views)
