Multisim and Ultiboard
Installation problem
I've having installation problem. I couldn't install NI Circuit Design Suite Education 11. The problem is during the installation of NI Circuit Design Suite Education, it ask for NI ELVISmx installer. I have already downloaded NI ELVISmx installer separately. But still i couldn't show NI ELVISmx installer when NI Circuit Design Suite Education ask for it. So i tried another way. I installed NI ELVISmx before installing NI Circuit Design Suite Education but still i couldn't show the NI ELVISmx installer when NI Circuit Design Suite Education ask for it. can anybody here help me out with that problem?
Thank you
(3,935 Views)
This is the version that i installed for ELVISmx.
(3,931 Views)
Here's the step by step screen shots up until i faced the problem. I hope this's help u 2 make clearer of what i'm having problem.
(3,923 Views)
Accepted by metalhorn
Hi metalhorn,
If you have already installed NI ELVISmx, then you won't need to install it again. In step 4 of your screenshots, there is a list of 2 features, the second being NI ELVISms 4.x. Click the button to the left and select to not install this feature. You should be able to finish the installation. The associated features in Multisim will still be available.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,902 Views)
