Multisim and Ultiboard
Issues with Single Frequency Analysis
Hi all,
I recently installed multisim 13 on a new computer. I went to do a simple single frequency analysis of an RC circuit and got some funny results. The magnitude of the voltages measured by the probes seem to be off, and I have never experienced this on any other computer I have used. I have tested it in multiple circuits and always get the same problem. I was wondering if there is some setting I am missing that will change this, but I have searched forums for two days now and haven't come across this particular issue. I have attached some images to show what I'm describing.
Thank you
(4,674 Views)
Double click the AC source and check that your AC magnitude setting is correctly set, by default it is set to 1V.
Tien P.
(4,542 Views)
