Multisim and Ultiboard
multisim
In the attached circuit, resistor R4 is 10 ohm but has a fault of 1 ohm leakage resistance applied. The digital multimeter measures the correct current if the leakage resistance is applied, but the current probe does not. Can someone help me understand what is wrong here? Is this a bug in the software?
(4,744 Views)
The attached circuit shows what the leakage resistor from R4 appear to the simulator.
Tien P.
(4,671 Views)
