Multisim and Ultiboard
LM2577S step up converter
i want to construct DC DC step up circuit,include of capasitors,resistors,indoctor,rectifier diode and.
i cant find  LM2577S in multisim components !!
i want to step up the DC voltage from  5VDC to have output voltage =24VDC.
i want to construct same circuit like in the attachment,but i am not sure of the components value so that i can achieve 24VDC as step up output voltage
any suggestion or guide is appreciated.
(5,073 Views)
There is no available model for the LM2577Spart. There is a wide range of converters and controllers that can definitely help you design and simulate your boost converter under the libraries: BASSO_SMPS_AUXILIARY and SWITCHING_CONTROLLER under the Power group in Multisim's library.
Mahmoud W
(5,069 Views)
