Multisim and Ultiboard
High Side Driver Models
Anyone know of any High Side Driver models similar to a VN5012AK?
(3,579 Views)
Thank you for brining this issue to the forums. Let me know if I have this correct, you are trying to bring in the VN5012AK model into Multisim in order to run some simulations.
Do you have a SPCIE model or any other type of model? (Hopefully we can convert this model into a Multisim format).
Also, have you tried contacting the manufacturer of this IC to see if they have any models that you can use for simulations?
Thank you,
Vimal Fernandez
(3,560 Views)
Thanks for the reply.
I'm fairly new to Multisim. I am unfamiliar with all the functions and capabilities of it, so I am generally unaware what to do if a part isn't in the multisim directory.
I do not have any spice models for the part, and I have not contacted the manufacturer either. I will contact them to see if they have any spice models.
(3,556 Views)
Hi Pauly,
If you can find a SPICE model for the component, have a look at this tutorial to create the component and add it to your database.
http://zone.ni.com/devzone/cda/tut/p/id/3173
I didn't find a model for the part you mentioned, maybe you can look at other manufacturers.  I did a quick search, I found a high side driver from Microchip:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010677
Tien P.
(3,529 Views)
