 Pauly_D
			Pauly_D
			12-15-2011 02:42 PM
Anyone know of any High Side Driver models similar to a VN5012AK?
12-16-2011 10:14 AM
Thank you for brining this issue to the forums. Let me know if I have this correct, you are trying to bring in the VN5012AK model into Multisim in order to run some simulations.
Do you have a SPCIE model or any other type of model? (Hopefully we can convert this model into a Multisim format).
Also, have you tried contacting the manufacturer of this IC to see if they have any models that you can use for simulations?
Thank you,
Vimal Fernandez
12-16-2011 10:28 AM
Thanks for the reply.
I'm fairly new to Multisim. I am unfamiliar with all the functions and capabilities of it, so I am generally unaware what to do if a part isn't in the multisim directory.
I do not have any spice models for the part, and I have not contacted the manufacturer either. I will contact them to see if they have any spice models.
12-19-2011 01:49 PM
Hi Pauly,
If you can find a SPICE model for the component, have a look at this tutorial to create the component and add it to your database.
http://zone.ni.com/devzone/cda/tut/p/id/3173
I didn't find a model for the part you mentioned, maybe you can look at other manufacturers. I did a quick search, I found a high side driver from Microchip:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010677
