Multisim and Ultiboard
Can't see the output window in Ultiboard 2001 SP2
I have been running Ultiboard 2001 for many years, as it is adequate for my needs. I recently had a HD crash on my old laptop, and had to re-install the UB 2001 software on my new laptop (Dell E-series, Windows XP, SP3). All is basically OK, except that I cannot get the Output window to disply, so I am unable to see any DRC checking info, connectivity errors, etc. The Output window is checked in the View menu, but checking or unchecking makes no difference. I have Ultiboard 2001, SP2. All other windows & toolbars seem to display correctly.
(3,683 Views)
Hi Dave,
It is possible that the Output window was dragged outside of the Ultiboard screen.  Have a look at the attached screen shot, notice a small Output window outside, if you see something like it, drag it back inside.
Tien P.
(3,672 Views)
Tien,
Unfortuntaely, that does not appear to be the problem. I actually looked for something like that when I first realized that I could not see the output window. Anything else I can try?
(3,667 Views)
Hi Dave,
Connect your laptop to another monitor and change the display to a dual screen, maybe it's on another screen.
Tien P.
(3,659 Views)
I don't have that option right now, and since I have never used dual screens, nor ever had the output window available, I don't see how the output window could have been sent to another screen.
(3,655 Views)
