Multisim and Ultiboard
LM324 oscillator does not function, why??
This is a typical noob question I am afraid..
From the datasheet of the LM324 I found (page 13) a circuit design for an oscillator. http://www.ti.com/lit/ds/symlink/lm324-n.pdf
I have been trying to reproduce this oscillator in MultiSim, but it does not work as it is supposed; even measure voltages much higher than the source voltage ??
Can anyone tell me what I am doing wrong?
(5,495 Views)
The LM324 have three different models, I selected the one made by National Semi and this circuit is now generating a pulse.  Double click on the LM324 then select the Replace button, in the "Model manuf" area, you should see more than one models.
Tien P.
(5,492 Views)
Accepted by spookm
TYhnak you, it works great now.
The model manuf button shows only ITT/LM324A_2
Maybe this is also due to my ancient version 10?
Thnaks you very very much!
martin
(5,488 Views)
Now I have a new problem with this LM324...
When I put more packages in a circuit, I cannot have U1A, U1B etc.
When I place the B component, I get a popup telling me that components are renamed.
I get strange pin layout and have to connect Vcc and GNd for every part.
See attachement
(5,469 Views)
Thnak you.
it works great with this component.
I cannot save it to the database though.
it seems that I have two versions somehow conflicting.
Do I have to do something special to prevent trouble from using your Lm324 version.
is it automatically storesd in the databse obne I opened this file?
(5,460 Views)
Since you already have this component in the Master database, you can edit it and add this model.  You can extract a model in a circuit by selecting Transfer>>Export Netlist, open the .cir file with Notepad and you will see the model. I've done it for you and the model is attached.
Have a look at this knowledge base to add a model to an exist component:
http://digital.ni.com/public.nsf/allkb/2373E75D8B375EA1862575D2004D9C88
Tien P.
(5,452 Views)
