Multisim and Ultiboard
LM324N in Ultiboard
Hello!
I used four Opamps of a single LM324N in my circuit, but when I transfered to ultiboard, my layout was created as if I were using one opamp of four different LM324N's. I really need a layout with a single LM324!
Somebody help me, please!
(3,252 Views)
Hello Wesley
I'm going to show the procedure to add 4 OpAmps of the same chip in Multisim, please let me know if it is how you are doing.
- Search for the component you want to use (figure 1);
- Click OK;
- Select the A button (figure 2). Doing that you're selecting to use the OpAmp A of a new chip;
- From there on, you can keep adding more OpAmps of the same chip clicking on the buttoms U1 - B, C or D (figure 3).
Every time you select a component that is already on the schematic, you will be asked to choose if you want to use a existent chip or a new one.
PS. You can change later the sub component you want to use on the component property (figure 4).
Please let me know if the issue persist.
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
(3,190 Views)
Thank you!
(3,173 Views)
Good to know it worked.
Please feel free to mark the post as an answer and kudo me.
Plínio Costa
(3,164 Views)
