Multisim and Ultiboard
Need help with creating a BCD to 7 Segment Decoder using Logic Gates
I guess I'm a bit stumped here.  I'm trying to create a 7 segment decoder with AND, NOT and OR gates, but I don't seem to be having any luck with getting the display numbers 1, 4 and 9 to work.
Any help would be appreciated, thanks.
(24,826 Views)
Accepted by topic author NickZF
Spent a bit more time before you look at this link:Smiley Happy
http://circuitscan.homestead.com/files/digelec/bcdto7seg.htm
Tien P.
(24,797 Views)
Thanks, Tien.  I re-analyzed my logic and it turns out I made a few silly K-map mistakes.  The updated circuit is attached if anyone is interested.
(24,785 Views)
I tried this and it worked on multisim. But when I'm trying to connect them on my breadboard they all light up no matter what switch are 1s and 0s. I'm using a 4-input dip switch. Any help?
(15,884 Views)
Do you know if the 7 segment LED you used on the breadboard a common cathode or common anode?  Have a look at this to see how the LEDs are connected internally:
http://ee.hawaii.edu/~sasaki/EE361/Fall06/Lab/7disp.html
Tien P.
(15,816 Views)
NEED HELP IN CREATING A 7 SEGMENT DECODER CIRCUIT USING NOR GATE
(15,370 Views)
Hi mate do you have still a copy of your kmap in this circuitry?
(10,073 Views)
