Multisim and Ultiboard
Layout in Ultiboard
Hi, I am currently developing a design for a senior design project. I have put together a schematic using Multisim, when I transfer the schematic over to Ultiboard and do autoroute it has problems completing every connection. I need to place vias and connect them from the copper top layer to the copper bottom layer. For some reason once I place the corresponding vias they do not connect. Can anyone help me with setting up the vias so that they connect? Thanks!
(3,157 Views)
I know this is not an answer to your question, but Ultiboard automatically places vias for the autorouting and it it couldn't find a path (based upon your description) then you probably are not going to be able to manually route it. I have run into this before. What I had to do is find which net was giving me the problem and try to place the component in a different location and try the autorouter again. Most of the time it works.
If you think you can manually route it the try the "Follow Me" tool or the "Connection Machine Tool" after placing your vias and see what happens. When I tried this on a test, the trace avoided the via like the plague and would not connect up to it and I don't know why even after assigning a net to it. This last thing may be a bug that needs to be addressed if we are both doing it right.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,140 Views)
