Multisim and Ultiboard
Linux install of NI Multisim 10.1 using Wine
I know Multisim isn't supported for Linux, but I was hoping someone from the community has successfully installed Multisim 10.1 using Wine.
Despite running "sh winetricks fakeie6 gecko dotnet20" on the shell before running the installer, the installation still fails stating it needs IE4 or newer.  I assume this is a required component due to the online activation screens, but do I really need to install IE6 on my machine?
I'm running openSuSE 11.0 (2.6.25.16-0.1-pae), wine 0.9.64, and Multisim 10.1.
Thanks to anyone who can help!
-Jason
(22,150 Views)
I've got the same problem.
I'm running wine-1.0.0 on slackware 12.1
 The Multisim installer says it needs IE 4 or better, and the ie6 installer says a newer version of internet explorer is already installed.
Since there's enough support for applications needing IE under wine, there must be a way to install multisim, is there?
(22,129 Views)
Just to update others, I was never able to get the NI installer past the initial steps using Wine on Linux.  I recently moved to a Mac running OS X 10.5 and am using Multisim successfully over VMWare Fusion.  I suspect Parallels would work just as well.
(20,431 Views)
Thanks for the update -- re: Parallels, I have been running Multisim on my Mac (using Parallels to virtualize an XP machine) for a couple years now and it has always worked well (and fast!).
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(20,420 Views)
VirtualBox is also a good alternative. It is small, fast and pretty efficient. You can Multisim in seamless mode and it works well.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(20,414 Views)
