Multisim and Ultiboard
Losing solder mask layers Ultiboard 14 Student Edition
Hello Arkosh
Have you tried to use only one layer then verify if the solder mask still there?
Regards
Message 11 of 17
(2,261 Views)
I have. I know it's there because I can change layer names, and I can't change, for example, "Silkscreen Top" to solder mask, as it is not a unique name
Message 12 of 17
(2,259 Views)
I think the student version does not support solder masks, the education version does though. For some reason the masks appear when first creating the file but disappear when reopening. I don't think has to do with the two layer limit, I think that limit is for autorouting only.
Message 13 of 17
(2,256 Views)
Well that's quite annoying. Thank you!
Message 14 of 17
(2,253 Views)
Yes, extremely annoying! When I made a board I just left the file open for days and then exported the Gerbers when i was done to send to the board house..
Message 15 of 17
(2,251 Views)
I am also experienceing this issue
It has nothing to do with student edition limits
I have used ultiboard several times with sodler mask and 2 layer boards.
This is something new and is also screwing me over
What is the solution to this National instruments
Message 16 of 17
(1,972 Views)
So i spent my entire day on the phone with NI. A company i have given tons of money to.
for many many versions of their software. A company that develops software for in the hopes that future engineers will continue to use when they hit the workforce
I have built 2 layer boards with solder mask on many occasion. Now after building 6 boards for a senior design project NI tells me the student version does not support solder mask. Regardless of the fact that i have produced many boards prior to this without issue.
Building a board without solder mask is completely useless. Its NOT a pcb at that point.
Its just a bunch of copper traces all over the place.
Well guess what NI! I will no longer be using your product after this. To sell a pcb design software that will not allow solder mask because they want more money is disgusting. The software is no longer useful and is void. I should have my funds returned to me.
I will be DITCHING all my NI SOFTWARE in favor or Orcad or eagle.
If this is how NI treats their customers i will not be one anymore.
This is pure capitalistic greed and the number one reason the world is screwed up.
NO MORE NI
I will also be making a you tube video about this.
Search for it!
Message 17 of 17
(1,950 Views)
