Multisim and Ultiboard
MAX3221E Master Database has wrong pin numbers
FYI,  the MAX3221E and variants has wrong pin numbers in the master database.  i.e. Vcc should be pin 15 not 16, ...
(3,581 Views)
Accepted by dbur
Hi David,
Thanks for reporting this. I am not sure why this component was created incorrectly. All components starting with MAX3221 in our database are effected. I'm uploading a file which you can import into your database which has the correct pinout.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(3,555 Views)
