Multisim and Ultiboard
Making custom footprints in ultiboard and multicap
I have a couple questions regarding custom footprints and their use between ultiboard and multicap.  First off in ultiboard I modified a couple existing footprints - a ssop20 and a sot23-3.  Basically widened the pads a bit and spread.
I want to be able to transfer back and forth from schematic to PCB, so in multicap when making a new component I am able to choose my custom sot23-3 footprint under 'user database', but that footprint has a transistor associated with it and I change it to reflect the ID of a voltage regulator with the same footprint.  I can't transfer back to the PCB with it like that -- Do I need to have a footprint for every component in Ultiboard or is there a way for a generic custom footprint to be available to whatever component value I place on it?
Second - modified the ultiboard ssop-20 footprint, saved it as a user custom.  It isn't available to me in multicap - why not?
Basically is there a good reference for working these databases together - I've read the doc 'Create new Component in UB' and followed it but alot of the directions don't seem to work.  In the beginning it talks of making a new component without wizard - the shortcut keys for coordinates don't work on my setup.  Secondly can't you make a new component with an existing custom footprint or do you always have to layout the pads?  And again in the section for making the custom part available to multicap - I got one to work, but is non-transferrable and the other doesn't show up.
(5,227 Views)
well  seems I've answered it myself - I get the databases to work if I make a new component in ultboard by doing the complete layout.  It doesn't seem to work if you want to copy and modify and existing footprint.
If anyone knows different, I would like to know the procedure.
(5,224 Views)
I spoke too soon.  Again I have one custom footprint from ultiboard available in multicap another one is not.
I close and restart the programs hoping that would fix - doesn't.  I'm missing something because I went thru and built both components from pad up, they have the same fields - REFDES, SHAPE, VALUE.
One component is available the other not -- what gives??
(5,221 Views)
Try the suggestions listed on these knowledgebases... I think this will help you...
http://digital.ni.com/public.nsf/allkb/B0077C481ED8E47B862572110061FA6B
http://digital.ni.com/public.nsf/allkb/7fcbde7e249d6cce8625721400561a51
Nestor
(5,193 Views)
