Multisim and Ultiboard
voltage-frequency
Hi all,
I am trying to build a spice model to become voltage-frequency but I’m having a lot of troubles by using real components.
Does anyone a virtual component in Multisim able to become voltage-frequency or any other way that I can control the frequency of the clock source?
Thank you very much
Roosvelt
(4,481 Views)
Have you tried the Voltage-Controlled Square-Wave source?
Place >> Component... >> Master Database >> Sources >> Controlled_Voltage_Sources >> Voltage_Controlled_Square_Wave
Nestor
(4,477 Views)
Yes Nestor,
I have tried the Voltage-Controlled Square-Wave source, it’s the perfect component for my purpose but its main limitation is the capability to change the duty cycle by external components.
Do you know any way to vary the duty cycle by external components or by spice syntaxes? The model that I’m making will be inside an integrated circuit that’s why I need to program the frequency and duty cycle by using external components.
I appreciate your help Nestor,
Roosvelt
(4,470 Views)
Not that I know of... for that purpose I would suggest the answer user Lacy gave to you in the other posting:
http://forums.ni.com/ni/board/message?board.id=370&message.id=340
That looks easier...
Nestor
(4,466 Views)
