Multisim and Ultiboard
Messed up Multisim 13
I´ve used Multisim 13 for about a month now and everything have been Ok until today.
Dont know what the problem is an are now seeking help.
Se attached pic.
When openening my projekt nothing works. Several components are messed up.
Don´t know how this suddenly happend.
It does not care wich project I opens. It is a mess.
Starting a new projekt works fine but I really dont want to rewrite all.
Anyone?
Thanks //EjnarMultisimMess.jpg
(4,863 Views)
Hi Ejnar,
I've seen this before. A reinstlall of Multisim should solve the issue. Give it a try and let me know.
Best,
Bozhidar
(4,835 Views)
Thanks for the answer Bozhidar. Seems that I have to follow your advise.
I did peek around a little bit and I managed to solve the issue concerning the components.
Did an update of all components in the Tool menu and that went well. But all the net lines became a total mess.
So it seems that I have to reinstall the whole thing.
Also found a securitybackup of the project but then again, Is it trusworthy?
(4,829 Views)
I would advice you firstly to reinstall Multisim and then opening the project, or at least make a backup if you open it.
It seems like there is some corruption in Multisim, which can mess your backup also, so the best will be to reinstall and then open it.
Best,
Bozhidar
(4,824 Views)
