Multisim and Ultiboard
Multisim Schematic Capture
How do I join 2 or more schematic  captures/circuits into one circuit?
(4,601 Views)
If you created two schematic drawings and you want to join them into one design, you have to use Hierarchical block.
In Multisim select Place »Hierarchical block from file. You will drop two blocks on one main page, and to connect the two blocks, you need a connector. Double-click the block»Open subsheet to expand the circuit. The connector is located under Place»Connectors»Hierarchical connector. Connect the connector to the node you want the pass the signal to the other schematic. Refer to this tutorial for more details:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGtjCAG&l=en-US
You can also refer to this tutorial to learn how to use the on-page/ global connectors to connect one schematic to another virtually:
 https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGurCAG&l=en-US
Tien P.
(4,572 Views)
