Multisim and Ultiboard
Micrel MIC2876-AYMT-T5 regulator problem
I am using the Micrel MIC2876-AYMT-T5 regulator on my new board. Unfortunately it is not working correctly.
I need 5Vout for 3-4 Vin and load current up to 2.5A. But the output voltage is stable only for 3.7-4 Vin. For Vin < 3.7V the output voltage starts oscillating and drops gradually.
Also interesting to note is that if the regulator powers-on while Vin > 3.7V and only then I reduced the voltage gradually bellow 3.7V, the output remains stable.
Can you suggest what could be the reasons for this behavior?
Shimshon
Message 1 of 1
(3,557 Views)
