Multisim and Ultiboard
Multi-page bus rotation problem
I'm running into some trouble using bus connections on a multi-page schematic.
On the main page, I've created two subcircuits. Both contain a bus (RFBoard-data), with  hierarchical bus connectors.
On the main page bus connection pins show up on both subschematic blocks, however one of them is rotated:
If I open the edit symbol screen I cannot change the rotation.
Deleting and recreating the connectors has no effect. This happened twice on my schematic. How can I fix this?
(2,516 Views)
It seems like using an off-page connector is the way to go here:
http://zone.ni.com/reference/en-XX/help/375482A-01/multisim/buses/
Buses with the same name are parts of the same bus. They need not be connected physically. To connect a bus to other pages of the same design, use Bus Off-Page Connectors, as in the examples shown in the figure below (1).
https://forums.ni.com/t5/Multisim-and-Ultiboard/multi-page-connections/td-p/814281
Jack
(2,479 Views)
