Multisim and Ultiboard
Multisim Thermometer-Issue
I,m currently using Multisim 11.0
Hello everyone! I am new to Multisim and need some help with my project. First i'll explain what i want to accomplish with my circuit:
I want to simulate a thermometer that flashes green when a specified temperature is reached (for example: >50 Celcius) and red at another specified temperature (for example: <50 Celcius). I want this to work automatically, but I couldn't find the correct resistor to do that (My teacher told me it is called NTC-Resistance) so I'm trying to make it work manually instead.
Well, now to the problem...
I can't make the LED-flashes work! I've tried adjusting the percentage on the both resistances, nothing happens! I've connected a voltagemeter between the LED's and it doesn't give me any value. Could someone help me fix this problem?!
(4,612 Views)
Without look at what you are doing, it's hard to know where the problem is, you should post your circuit.
Tien P.
(4,585 Views)
