Multisim and Ultiboard
Multisim voltage drop
Hi, I am new to multisim and when I hook up a simple circuit with a  10V battery, ground, and a resistor and use the multimeter to measure voltage on each side of the resistor, it shows 10V instead of the correct amount. Any suggestions on what I could be doing wrong?
(3,506 Views)
can you please attache the file of the reading, there are many possible reason and we will require to discard some by looking at the file
(3,461 Views)
