Multisim and Ultiboard
Multisim
I'm unable to change what the AC power sources measure in I have vpk but I cant change it to vrms
(3,037 Views)
Hi Lazlo123,
If you are using Multisim Live and you are referring to AC Voltage/Current source, the value cannot be changed to rms. You have to multiply the rms value by √2 and use the result as peak value. If you are referring to measured values of a probe, rms value can be displayed by enabling Periodic measurement. This is done by selecting the probe, opening the Configuration pane, then checking Periodic in Measurement labels.
G. Goodwin
(2,995 Views)
How do I find Vpk on Multisim online when using AC Volatge?
(2,816 Views)
