Multisim and Ultiboard
Net name with no wire
I have a multipage schematic the uses many buses to other pages. I noticed on one sheet that a net name seemed to be sitting all by itself in the middle of the screen. I can delete everything on the sheet but this rouge net name is still there. If I double click on the net name it brings up the dialog box asking if I want to lock the net name in position. This net name does not appear in the spreadsheet view of the Nets either.
(3,954 Views)
I can confirm this as happening to me also. I don't remember the circumstances under which this occurred and so far it hasn't happened since that one time (Unfortunely, I have apparently deleted the circuit where this occurred). I have no solution to this because I can't get it to repeat it. I thought I would just let you and the NI Team know that it has happened to more than one person. I will be interested in what they have to say on this in case it happens to me again at some point.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,951 Views)
We have seen this case from time to time and we are currently on it.
As of now, you can go to Options >> Sheet Properties, set your netnames to Show All, click apply and ok... then go back to the window, nos set the nets to Hide all... click apply and ok...  and then turn them back on... it should go away...  this procedure cleans and rebuilds the nets table...
Nestor
(3,941 Views)
Thank you so much. I solved my problem just now.
(3,377 Views)
