Multisim and Ultiboard
New user ultiboard
Hi All,
I am a new user for Ultiboard, I trying to modified an existing PCB  by placing components directly in Ultiboard . "Ultiboard doesn't correct any errors when you don't have a schematic". Kindly, I was wondering if anyone can take a look at this board and tell me if it is a working board. \
Thank you,
XAYA
Message 1 of 18
(4,734 Views)
Message 2 of 18
(4,732 Views)
1. Tools>>Netlist Editor
2. Net>>New>>1
3. Pins>>Add>>LED1,PinA + R2,Pin2
4. Net>>New>>2
   Net>>New>>...
Message 3 of 18
(4,730 Views)
Hi supsup,
Thank you for your help, Im still having problem with the PCB. I can still see red circles on the corners of the traces and cannot have a clean pin connection with the trace. Any advise please? Do you know a good tutorial I can use?
XAYA
Message 4 of 18
(4,714 Views)
Hi xaya,
Whether you have created all nets? Attach your last Ultiboard file, please.
Message 5 of 18
(4,708 Views)
here it is
Thank you
 Xaya
Message 6 of 18
(4,704 Views)
Hi xaya
1. View>>Spreadsheet View
At creation of the list of nets you have made many errors. Check up a widht of traces. Use Help file.
Message 7 of 18
(4,701 Views)
I changed the trace width maximum to 1mm and clearance 0.1000mm  but Im still having the same errors. Is there a default rule (for beginners) that can be used to avoid errors for basic work?
Thank you.
Xaya
Message 8 of 18
(4,696 Views)
Sorry missed the file 🙂
Message 9 of 18
(4,694 Views)
Now at you other errors. You have incorrectly made the list of nets. Rectify all errors!
Message 10 of 18
(4,693 Views)
