Multisim and Ultiboard
Phone charger circuit unable to simulate, please give advice.
I made a charger circuit using a transformer, diodes and capacitors. Then will transfer them onto ultiboard to make PCB. However this circuit is not working as expected, the transformer and the capacitor blows up and the multi meter is showing very small voltage. The volt meter should show a voltage of 2v but this is not happening. I have attached my file, please have a look.
Youtube video:https://www.youtube.com/watch?v=6aapu9kosto
So I copied that circuit in the youtube video but it does not work.
(1,462 Views)
Пожалуйста, в формате "ms" скиньте
(1,438 Views)
Please can you speak english, I have to use google translate otherwise.
You said: "
Please discard in the "ms" format
Please explain clearly what you mean by 'discard'.  I can't upload the .ms14 file since I get an error.
(1,422 Views)
