Multisim and Ultiboard
Pin contact mode in UR broken
I've specifically told UR NOT to use pin corners and after running the autorouter to 100% these are the results. Clearly not functioning correctly.
After reading the help file I'm under the assumption that if I say no, the trace should only contact the pin at 3, 6, 9 and 12 o'clock positions.....which clearly this image attached proves that is not what is happening.
Anyone else.....advise?
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,367 Views)
 Hi Chris,
I played around you the settings and I was not able to control the trace entry either, I am going to create a defect for this issue.
Tien P.
(3,341 Views)
Thank you
(3,338 Views)
