Multisim and Ultiboard
Dipswitch erorr
INestor,I thought I would bring this to your attention. I do not know if this issue has previously been discussed or not. If it has and your already aware of it then accept my apology.
It seems like the DSWPK_5 Dipswitch is malfuntioning and returning errors. Below I have posted my simple test circut  you take a look at. I tested the rest of them and they are O.K.. Just this is is causing problems.
Here's the files and Error Log:
Too few parameters for subcircuit type dpswpck5j1 (instance: xxj1)
Error: unknown subckt: on line 198:xmm1 1 0 xxmm1_368330984
Error on line 198 in C:\DOCUME~1\OWNER\LOCALS~1\TEMP\02.CIR.cir: xmm1 1 0 xxmm1_368330984
 unknown device type - error
Instrument operation performed   (2007, August 07, Tuesday, 22:15:14)
|   Instrument Analysis:Transient Analysis
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions:Automatically generate initial conditions
|   |   |   Starting time (TSTART):0
|   |   |   Stop time (TSTOP):1e+030
|   |   |   Plotting increment (TSTEP):automatically calculated (less than:1e+030)
|   |   |   Maximum time step (TMAX):automatically calculated (less than:1e+030)
|   |   Perform consistency check
|   |   Variables from analysis
|   |   |   Show device values at the end of the simulation
|   |   Representation as SPICE commands
|   |   |   begin-scope page
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+012
|   |   |   -param hrange 0 1e+030
|   |   |   save
|   |   |   tran  -env-options 1e-005 1e+030 0 1e-005 auto_ic auto_tstep auto_tmax
|   |   |   if-error end-scope audit-log-show
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   Multisim Default Analysis Options
|   |   |   Truncation error overestimation factor: 7
|   |   |   Upper transient iteration limit: 100
|   |   |   Enable convergence assistance for code models
|   |   |   Shunt resistance from analog nodes to ground: 1e+012
|   Output from instrument analysis
Message Edited by lacy on 08-07-2007 09:38 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,245 Views)
Hi Lacy,
I was able to replicate the problem and I will create a defect for this component.
Tien P.
(4,219 Views)
Thanks Tien. All the responses and help that the NI team provide is greatly appreciated
Have a Nice Day
(4,214 Views)
