Multisim and Ultiboard
Please provide information about the component 3288 RT
Dear NI support team,
       Please provide detailor datasheet of component 3288 RT.
(6,964 Views)
Hi Robin,
Thank you for contacting National Instruments.
I am attaching the component detail report for 3288RT.
In Multisim, in the 'Select a Component' Window, when you select any component, on the right side you will see this option 'Detail Report'
You can find the detail specifications of the component here. Also you can view the component model by clicking on 'View Model'.
Hope this helps.
Kanchan Bhakoo
Applications Engineer | National Instruments
(6,941 Views)
Dear support team, I tried to use 3288RT and 3554AM with differential input voltage 48V and 5V Vs+ and -5V Vs- as non inverting amplifier circuit. I attained 96V at output. Since i am not sure whether it is possible on board. Can you tell me whether such amplification is really possible on boards. I am looking for datasheet of 3288RT, to understand internal circuitry and working.
(6,933 Views)
