Multisim and Ultiboard
Problem using Model Maker to generate an NMOS transistor
I'm attempting to use Model Maker to create a custom NMOS model, but when I attempt to use the resulting model in Multisim I get a "unable to find model definition" error.
Here is the procedure that I am using:
Component Wizard
Simulation Only
Single Section
3 pins
Copy 3 pin Enhancement mode symbol from DB
Default all bidirectional
Model Maker
MOSFET(4 pins: D,G,S,Sub)
I've tried making my own, but all defaults give me the same error as customizing the fields, so I just click OK here.
Model Name is filled in as MOSFET_MODEL_BSS83
After the comments section, the generated model looks like:
.MODEL Mosfet_MODEL_BSS83 NMOS
+ VTO=1.230e+000 PHI=6.500e-001 GAMMA=3.134e-001 LAMBDA=2.039e-001
+ KP = 1.461e-002 RD = 1.250e+001 RS = 1.250e+001
+ CBS=2.372e-012 CBD=1.977e-012 IS=2.500e-014
+ CGSO = 7.200e-009 CGDO = 6.000e-009 CGBO = 1.800e-009
+ MJ=4.600e-001 PB=8.000e-001  FC=5.00e-001
Connect S->3, D->1, G->2
Save to a user database and finish.
Add part to schematic
Hit simulate:
error in c:\docs\...\temp\02.CIR.cir(24):mU1 VCC Probe1_0V_SP_NODE 0 MOSFET_MODEL_BSS83__TEST__1
Error on line 24 in same as above
unable to find definition of model - default assumed
BJT's and diodes work fine when contructed using the same method.
I'm using Multisim 10.0.343 Power Pro Edition
Any help is appreciated.
(3,816 Views)
The Mosfet from the component wizard expects you to have 4 pins. If you only assigned 3 pins because your symbol only has 3 pins, this issue will arise. This is a limitation that will be addressed.
For now, if you dont want a 4th pin, the easiest solution is to wrap you mosfet in a subcircuit and run the component wizard where you manually paste the subcircuit into the model text box. Here's the template:
.subckt mymosfet_anyname d g s
M1 d g s s mosfet_model_name
.model mosfet_model_name nmos("parameter goes here"......)
.ends
where you would place your desired mosfet parameters in the brackets
Let me know how it goes...
Max
(3,807 Views)
That's a cool trick Max. Thanks for that information. If I ever need to create a Mosfet I will rememember this method. In fact, I am going to copy this information a place it in a safe place for future reference.
Very much appreciated, Max
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,799 Views)
