Multisim and Ultiboard
Problem with 7447 zero suppression
7447 zero suppression doesn't work in Mulitisim 10. Can anybody solve this problem or tell me how to realize this function?
circuit attached.
(6,008 Views)
This is an interesting little situation. I believe you to be correct but it goes much deeper than that. When I tie RBI to ground it not only lights up all the segments, but it will not let the number selected be displayed. If I tie BI/RBO to ground it blanks the display and nothing is diplayed. I have tried everything I can think of to get the zero not to display while at the same time getting the selected number to show up. I have not been able to do this. Therefore your statement is correct that it not working properly. This will have to be one for NI to look at and see what they may have up their sleeve to get this to work correctly.
I never really noticed this as usually the zero never bothered me when doing my counting circuits. Thanks for bringing this to the forum's attention.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,997 Views)
Yeah, I have the same problems. Then I simulated in Proteus and found that it's better than in Multisim, but still not ideal. In the picture, you can see all zeros are suppressed except for the last one. So better than none. : )
(5,991 Views)
