Multisim and Ultiboard
transformer voltage measurement
I can not measure voltage at the exit of transformer in a simulation Multisim-demo. The ratio is 14.7 for 220/15V. Why?
(4,110 Views)
Here are a few rather simple suggestions. If you post your file I may be able to come up with a better answer.
1. Make sure you are tieing AC to the primary
2 Make sure both sides of the transformer has a ground.
3. Be sure the Multimeter is set to measure AC.
4. Be sure the Multimeter is grounded.
I know these are ridiculously simple things, but I have been know to screw up the simplest thing when wiring a circuit and I have been wiring them up for years with Multisim.
I hope some of this helps
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,102 Views)
Thanks a lot. Now it works fine with a ground at the entry, I am sorry I ignored " at least one ground"!
(4,093 Views)
