Multisim and Ultiboard
convergence error on counting circuit
Ignore all the extra stuff, alot of it was for troubleshooting so it looks messy.  It seems to give me the error when i hook the 7 segment display up to ground. If i just let it run without it connected, the leds light up approprately.  As soon as it's connected, i get convergence.  I tried all the time step stuff too.  No luck.
(3,631 Views)
Here's what I found. Goto SIMULATE>DIGITAL SIMULATION SETTINGS and change itr from IDEAL to REAL. This will require you to place the following power sources on the schematic somewhere: VCC, VDD, DGND, VSS.  This should get it simulating without the error message popping up.
I do not know why the 7-seg displays don't work under the IDEAL Setting, but most of the time I have observed that they don't. Usually when I am going to use them I have to set the simulator up as described above.
I hope this helps
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,615 Views)
Works great now thank you so much!
(3,607 Views)
