Multisim and Ultiboard
RTD with 0.04 adjustment
This is a school assignment and I am trying to use a variable resistor as an RTD because I cannot find an RTD in the list of components.  This RTD has to change resistance by 0.04 per degree, and I have no idea how to do that.  Can someone please walk me thru this?  I am using Mutlisim Version 13 if that matters.
This is the exact language from my lab problem if you need more information:
The RTD will generally operate between 80° to 175°C and has a resistance of 220Ω at 20°C. The fractional change in resistance per 1°C is 0.0040. The dissipation constant is 25mW/°C. Design a circuit to activate an LED alarm when the temperature reaches 150 °C. The error should not exceed +/-1°C. Use a single supply voltage.
(3,801 Views)
Hello!
I've found the following information that might be useful for you, it is the simulation of an RTD, check it and let me know if helps:
How do I Simulate an NTC Thermistor With Multisim?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHygCAG&l=en-US
Can I simulate an NTC thermistor with the RESISTOR_VIRTUAL component in Multisim?
http://digital.ni.com/public.nsf/allkb/6B56D525AB21781F862571D3004E5F0A
How do I Simulate a Pt100 RTD with Multisim?
http://digital.ni.com/public.nsf/allkb/3B8920EA67EA8531862571CA002E6FEF
Luis G.
(3,780 Views)
