Multisim and Ultiboard
Removing alignment targets
How do you remove the alignment targets from a pcb in ultiboard?
 Please see attachment. They are the cross hairs.
Thanks.
(4,887 Views)
Hi Arthur,
In Ultiboard, these are called fiducial marks. To turn them off
  1. Open Options  > Global Preferences. Select the PCB Design tab
  2. At the bottom right, uncheck Show fiducial marks
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,883 Views)
In the PCB Design tab of the Global Preferences (Options > Global Preferences), you will see the option to Show fiducial marks.  If you deselect this option, it should solve your problem.  Let us know if this solves your issue.
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(4,881 Views)
