Multisim and Ultiboard
oscilloscope color dosent match the wire color
When i make a connection to the scope input, i able to alter the wire color, then the signal in the scope screen changed too.
But when put an info bubble to the wire, the color in the scope goes to purple. And i cant change that.
(8,748 Views)
Could you possible have 2 overlaping traces that ciasue the color to be purple?  Put the info buble on a different wire to see what happens.
Tom
(8,740 Views)
Hi Lidi,
Thanks for posting this. It appears that this problem has been fixed and should not happen with our next release of Multisim. If you redraw the wire though, this problem should go away.
Hope that helps.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(8,729 Views)
Also, I would like to suggest the following work around for this. This behaviour is triggered by the probes which you have placed on the wires coming into the oscilloscope. A quick work around would be to right click the probe (the green arrow) and click Reverse Probe Direction. Next time when you start interactive simulation, the oscilloscope should draw the traces in the correct colour.
Yi
Software Developer
(8,676 Views)
