12-06-2012 02:32 PM
The history so far (using MS11):
I tried to make a new component, i.e. the CNY70.
Therefore I needed the simulation model. So I designed a simple subckt that I tested, and ok, it works.
Subckt schematic exported a netlist, lines added: .SUBCKT <name> 1 2 3 4 and .ENDS
This .cir file used as Model for the new part I created.
And then....used this new part in a testschematic.....and the simulation is aborted::::(
SPICE Netlist Error in schematic RefDes 'd1', element 'ud1': Unable to parse parameter name
SPICE Netlist Error in schematic RefDes 'd1', element '<unknown>': Due to errors, the component 'ud1' has been omitted from the simulation.
QUESTION: what did I do wrong / what am I missing in the Subckt file????
I looked in some modelfiles of opto-manuf. like Avago, and they all make use of V-controlled-I sources etcetera.
Capera
EWB/Multisim Educational Licence User since EWB9
12-13-2012 04:36 AM
Hello Capera,
I just saw that you had posted this question.
Is the issue still open?
12-18-2012 06:51 AM
Hi ThiCop
The issue is still open. Checked the forum for ideas, but none works.
12-21-2012 04:21 AM
Hello Capera,
I tested it and do get the same errors that you get.
Is it possible to provide me with some background information about the component you're trying to implement?
Is this a default available product "on the shelf"?
Or is this a custom made product?
01-22-2013 10:06 AM
Hi Thierry
The component is a standard CNY70 http://www.vishay.com/docs/83751/cny70.pdf
I wasn't even there that I wanted to simulate the lightreflection in the sensor.... which I would like to in the end....
But the question in general is why I can't implement the subcircuit as a component. The Netlist Error doesn't give very much information.
It's just stupid that it won't work. (I mean, I follow the UserManual instructions and yet it costs me 3 hours to end up with only this error ).
Hope you can find an answer... Thanks in advance!
Capera
01-28-2013 09:49 AM
Hello Capera,
I understand that spending alot time and ending up with an error can be extremely frustrating.
I did some further testing and it seems like I get the same error even with an empty model.
It seems to not be purely linked to this model.
Which specific steps did you follow?
