Multisim and Ultiboard
SPICE netlist error in schematic
I get the following error messages when I run the simulation.
Error: SPICE Netlist Error in schematic RefDes '', element '_uc2fffffffe*************':  Unsupported component prefix type '_'
Error: SPICE Netlist Error in schematic RefDes '', element '<unknown>':  Due to errors, the component '_uc2fffffffe*************' has been omitted from the simulation
Error: SPICE Netlist Error in schematic RefDes 'u1', element 'e_u3_e7':  Unknown controlled source table syntax in 'e_u3_e7:ad8336__vga__1'
Error: SPICE Netlist Error in schematic RefDes 'u1', element 'ad8336__vga__1':  Due to errors, the component 'e_u3_e7' has been omitted from the simulation
This just a test ckt for AD8336 chip.
thank you
Message 1 of 8
(31,431 Views)
Hi Halifax,
              I took a look at your circuit. It seems that the AD8336 component has not been created properly. There seems to be no spice model linked to it and thus you are seeing simulation errors. You can go through the component creation tutorial in the link provided and try to create the component again.
http://zone.ni.com/devzone/cda/tut/p/id/3173
Hope this helps.
Tayyab R,
National Instruments.
Message 2 of 8
(31,408 Views)
hey there
im also experiencing the same problem. please help
------ Checking SPICE netlist for TRT - 20 March 2012, 12:09:02 PM ------ SPICE Netlist Error in schematic RefDes 'u5', element 'xu5':  Invalid subckt definition name '21' SPICE Netlist Error in schematic RefDes 'u5', element '<unknown>':  Due to errors, the subckt instance 'xu5' has been omitted from the simulation SPICE Netlist Error in schematic RefDes 'u4', element 'xu4':  Invalid subckt definition name '23' SPICE Netlist Error in schematic RefDes 'u4', element '<unknown>':  Due to errors, the subckt instance 'xu4' has been omitted from the simulation SPICE Netlist Error in schematic RefDes 'u3', element 'xu3':  Invalid subckt definition name '25' SPICE Netlist Error in schematic RefDes 'u3', element '<unknown>':  Due to errors, the subckt instance 'xu3' has been omitted from the simulation SPICE Netlist Error in schematic RefDes 'u2', element 'xu2':  Invalid subckt definition name 'u2_open_y' SPICE Netlist Error in schematic RefDes 'u2', element '<unknown>':  Due to errors, the subckt instance 'xu2' has been omitted from the simulation SPICE Netlist Error in schematic RefDes 'u1', element 'xu1':  Invalid subckt definition name 'u1_open_rb7backslashkbi3backslashpgd' SPICE Netlist Error in schematic RefDes 'u1', element '<unknown>':  Due to errors, the subckt instance 'xu1' has been omitted from the simulation SPICE Netlist Error in schematic RefDes 'u6', element 'tu6':  Unable to parse parameter name ======= SPICE Netlist check completed, 11 error(s), 0 warning(s) ======= Error message from simulation: tu6: transmission line z0 must be given Error message from simulation: doAnalyses: No such parameter on this device Error message from simulation: tran simulation(s) canceled
O.P Lekgotle
Message 3 of 8
(31,076 Views)
Can you post your circuit so we can take a look at it.
Tayyab R,
Message 4 of 8
(31,057 Views)
Morning Tayyab R
im unable to attach i get the following error:
Please correct the highlighted errors and try again.
  • The file does not have a valid extension for an attachment. jpg,gif,txt,xls,vi,zip,doc,llb,pdf,png,ini,wsp,rtf,lvproj,lvlib,cfg,ppt,pps,csv,ms10,ms9,ms8,ms7,msm,prz,cir,ewprj,gbr,seproj,ms11,mp11,mpzip are the valid extensions.
O.P Lekgotle
Message 5 of 8
(31,031 Views)
You can place it in a zip folder and upload it.
Tayyab R,
Message 6 of 8
(31,018 Views)
thanx.. here you go.
O.P Lekgotle
Message 7 of 8
(31,007 Views)
The reason you have all these errors is because you have not created the layout components correctly. The header and connector should be layout components but they seem to have models which is not correct. When you are going through the component creation, you should select Layout Only components.
I have written a small document which shows you what you will need to do for all such component on your design.
Hope this helps.
Tayyab R,
Message 8 of 8
(30,992 Views)
