Multisim and Ultiboard
Same circuit twice with different results
I've been having some trouble having Multisim match a circuit I have modeled in MATLAB. During the troubleshooting process I put voltage probes on each wire used. The circuit portion in question involves an AC Voltage source connected to a resistor which is then connected to an inductor. I made a copy of the circuit and started from scratch. One of the circuits gives a voltage drop across the resistor, while the other one doesn't drop any voltage at all. I've checked all of the connections and they are all good. The only difference I can see is that one has the pins labeled 1 - 2 while the other is 2 - 1. Does anyone know what the problem is here? I shouldn't not be getting two different results for the same circuit.
(5,047 Views)
Hi Jmerc,
Maybe you can post the circuits so that we can compare.
Tien P.
(5,030 Views)
