Multisim and Ultiboard
Selecting multiple components by dragging
I'm using multisim online.
After I've drawn a complicated circuit with many components and many connections between them, I want to select a whole piece of it, in order to move it to make space, or even to duplicate it.
I would expect to be able to draw a rectangle by pressing and holding the mouse button, moving the mouse, and then releasing. Everything touched by or included in the drawn rectangle would be selected. This is how you select stuff in basically every graphic editor of any kind I've ever seen.
And yet this doesn't work in multisim. The only way seem to be to use the Ctrl+Key and click on every single component and every single connection.
And even if I do so, when I duplicate, it randomly duplicate most but not all of the things I've selected (in particular some connections are missing, even though they were selected).
I tried holding ctrl or shift while attempting to draw the rectangle, but nothing.
Am I missing something?
Message 1 of 1
(1,238 Views)
