Multisim and Ultiboard
Time span defaults to Time Minimum = 20 s and Time Max = 20 s
Greetings;
I ahve Multisim Premium Tier and not using any board.  I am trying to show an inductive spike by pressing the switch. I have the time min set to 0 sec and Time Max set to 20  sec.  The L/R  time constant  is 0.005 ms . When I run simulation and press the switch in the schematic, the graph displays     Time MIN 20 sec and Time Max 20 sec. I do not see a Voltage even when I scan the time axis every  roughly 0,5 second.  What are the recommended setting to view an inductive spike that has a time constant of 0.005 ms using a Vcc power supply and switch?
(1,022 Views)
Привет! . "Постоянная времени L / R равна 0,005 мс "-а так-ли это!?
0,001 H/ 0,001 Ohm=1 sec
(1,002 Views)
Смоделировал вашу схему в таком виде.
(974 Views)
