Multisim and Ultiboard
Simulate Menu not appearing
Hi
I installed the MultiSIM and UltiSIM. Since the network connection is slow the application is not able to connect to the server. But other pages are opening. And it says the software will function with limited facilities. And the Simulate Menu is not visible when the MultiSIM opens. Please tell me some corrective measures that I should take.
Thanks in advance.
Gokul.
(5,792 Views)
Gokul,
It appears that you are using the freeware edition (the free download from the www.electronicsworkbench.com website). This version is only a 45 day free trial and in order for it simulate it must connect to our server. Without a proper network connection, unfortunately the simulation feature will not function correctly, and this is the reason for the 'Simulate' menu not being available.
If your network connection is being hindered by a Proxy Server allow for the proxy server. If it is still not working, please contact your local distributor or sales department. They might be able to help you.
(5,756 Views)
