Multisim and Ultiboard
Simulate just a simple LM324 circuit but the result is incorrect
Hi guys,
I have a problem with LM324 simulation.
Here is my circuit:
I simulated it but the output of the opamp was just a DC signal which is theoretically incorrect.
Pls help me to find out where the problem is.
Thank you.
(5,864 Views)
Accepted by Sasuke
Check up connections of power supplies with the GND.
(5,847 Views)
Thank you for your answer. The +12V power supply was not connected to GND causing the incorrect result.
regards,
(5,842 Views)
