Multisim and Ultiboard
Simulate the output of a DAC
I am have been able to simulate a midi to analogue synthesiser. However the actual signal that will control it will be from a DAC. I am currently just using an AC signal, but is it possible to simulate a DAC? If so, how ?
Thank you
(3,215 Views)
Hi JackkSynth,
There are DAC components available inside of Multisim.
The following is a forum post discussing the two DAC's inside of multisim: https://forums.ni.com/t5/Multisim-and-Ultiboard/Digital-to-Analog-conversion-in-Multisim/td-p/328558...
You mention that you are using an AC signal as your output. Under ideal conditions that would be the output of a DAC of course. The following is a tutorial on how to create one also: https://forums.ni.com/t5/Example-Program-Drafts/Digital-to-Analog-Converter-Example-Circuit-with-Ana...
I do not believe there is a specific simulation for a DAC it would be a case of creating your own.
I hope this helps.
Matt
AE UK
(3,159 Views)
