Multisim and Ultiboard
Ic voltage regulator
Please can anyone can help me. I tried to build a circuit with bridge rectifier and voltage regulator (LM317). I found the equation to calculate R1 and R2 (Vout=Vref(1+R2/R1), but it doesnt work for me. I need 10V on output , but I only have 7.3V. I dont know what I'm doing wrong. Below is a screenshot of my circuit.
(4,571 Views)
Firstly just to confirm - I simulated the exact same setup (from the LM317 onwards) in multisim and got the expected 10V:
This must mean one of your resistors/components is labelled correctly but perhaps has the wrong value assigned to it.
Can you attache the actual multi sim diagram so that I can use your simulation to check?
Best Regards,
Roberto
NI UK AE
(4,509 Views)
thank you for you reply, and you right i was some bad connections.
(4,468 Views)
