Multisim and Ultiboard
initialize DAO/Jet db
When I installed evaluation version of multisim I got an error "unable to initialize DAO/Jet db".
I have found some solution in internet, but none is working (register, reinstallation). My operation system is Windows 8. I know also, that it is working for my friend (same system).
What could be reason of this? And how could I fix it?
Version of Multisim is 12.0.1.
I have also Microsoft Office 2013 (like my friend) if it could help.
(7,423 Views)
I just want to check if you've tried this:
http://digital.ni.com/public.nsf/allkb/A0D4BDCD8ED6F2C5862571B800565831
It seems it was not tested on Windows 8 so far, so I suggest checking the path first, if it is the same as described in the KB. Thanks for testing!
Jakub Prokeš
NIEE Aplications Engineer
(7,392 Views)
First, sorry for my late answer.
Of course I tried this. It was one of first solutions I've found. But it didn't help.
After all I decided to reinstall my OS. And... It worked. I think that was problem of Windows 8. So if anybody would have same problem do not be surprised when you'll have to reinstall Windows.
(7,329 Views)
Hey, I know that you have long since found the answer to your problem; but I was recently observing this same error every time that I tried to run my student/educator edition of Multisim version 14. I searched everywhere for an answer, I tried following the following procedure with no success:
I finally stumbled upon your post, which suggested reinstalling your OS. Anyways, long story short, I didn't want to go through that hassle so I kept trying things, and I found a solution for me that worked. Since I am getting this error 6 years later, I am sure others are too and I wanted to show an alternative solution for them if they experience this issue.
In my case, the databases were accessible when I opted to run Multisim or Ultiboard as ADMIN. This fixed this issue for me and made it work and able to access all the appropriate databases. I have to run it as admin every time, but I am under the impression that if you run the initial installation as admin this will fix the issue for good.
Good luck!
(4,627 Views)
