Multisim and Ultiboard
Simulation with Multisim
Hello, I need a help for a simulation with Multisim. I have to realize the following points:
1) Beginning from a square signal, +1 Volt and baseline at zero, realize a decreasing exponential signal with a time constant of 100 microsec;
2) Adding a variable gain amplifier, the signal must assume values between 1 Volt and 2 Volts (this point is to be realized with operationals);
3) The baseline must assume values between 0 Volt and 1 Volt (this point is to be realized with operationals).
I hope you will help me, I'm at the beginning with Multisim.
P.S. Sorry for my english!
(5,130 Views)
Have a look at the attache circuit, not sure if this is what you want.
Tien P.
(5,015 Views)
